I just installed the new front cover that was ported and set-up with new oil pump gears,i bought it last year for my new engine.
I primed the oil system with out a problem, so i know the gears are ok.
When i attempt to install the cam sensor it fits so tight that it won't turn by hand and it won't go down all the way to mesh with the cam gear and oil pump shaft, it almost seems like the oil pump shaft is bent and causing the sensor to bind and causing this.
Anyone ever experience this type of problem with a new cover / oil pump gears?
I really don't want to pull the gears out but it seems like what i will have to do. But at least the engine is still on the stand so that part will be easy.
Any and all suggestions appreciated :smile:
