cam shim wear?
any one think it will be ok to use as is? iam going with a flat tappet cam..with the cam installed all the way in it spins freely it does not seem to rub on the block...
No,don't try using it like that.
Your machine shop should be able to get the materials and fix the block if not then you need to find another shop.
I have only had 1 block that needed repairing like this and my local shop guys never batted an eye when i brought it to them to see if they could fix it,it didn't take them long at all since they had done them before and had the experience and know how.
Wear Shim
TA Performance has a siicone bronze shim i used on mine. had the block machined to the thickness of the shim and then they installed 2 roll pins so the shim would not rotate. Worked like a charm. Think the shim is .040
Mitch
