Camshaft timing - 23 degrees versus 25 ?
Discussion in 'Hot Air (non-intercooled) Tech' started by Hot Air Beast, Oct 11, 2017.
  1. Hot Air Beast
    Hot Air Beast
    Expand Collapse
    Hot Air Lover
    Mar 10, 2007
    159
    5
    Offline
    Is there any power advantage to setting cam timing at 23 degrees versus 25?
  2. Jerryl
    Jerryl
    Expand Collapse
    Doing MORE with LESS!
    Dec 14, 2004
    7,566
    287
    Offline
    Are you referring to the Cam sensor timing?
    There is an acceptable operating window for the cam sensor, that is much larger than +-2 Crank degrees.
  3. Hot Air Beast
    Hot Air Beast
    Expand Collapse
    Hot Air Lover
    Mar 10, 2007
    159
    5
    Offline
    Yup - the machine shop has the engine back in the car and i expect your pulley will arrive soon, if it isn't already there. When I rebuilt the engine back in 2008, I had two GM mechanics working with me and they believed that they had tweaked the cam sensor timing to 23 degrees ATDC, back in the day (late 80's) as they continued to learn about the car. Normally I would stick with whatever the GM engineers had recommended. If by chance the machine shop has used 23, I just want to know the upside/downside of doing so. Just being cautious here. Engine is bone stock and I am happy with that, and want to keep it trouble free as long as I can.
    Phil from Canada :cool:
  4. Jerryl
    Jerryl
    Expand Collapse
    Dec 14, 2004
    7,566
    287
    Offline
    Hi Phil,
    I am severely disappointed with the USPS and their S-L-O-W shipping to CAN for the price paid! Unbelievable but much appreciation gained for the challenges you guys face in CAN.
    There is no theoretical or any measureable benefits from changing cam sensor timing 2 crankshaft degrees from 25 ATDC, if the car is running correctly, especially on a stock set-up. FWIW; 2 degrees@crank will be 1 degree@camshaft. My suspicion for the "tweak"; Many shops believe cam sensor affects ignition timing and end up "tweaking", which is inaccurate.
    Here some reading material;
    http://www.gnttype.org/techarea/ecmsensors/camsensor_FAQ.html
    Hope that helps.
  5. Hot Air Beast
    Hot Air Beast
    Expand Collapse
    Hot Air Lover
    Mar 10, 2007
    159
    5
    Offline
    Thanks Jerryl - we had a three day week-end here for our thanksgiving so I expect nothing moved on Sat/Sun/Mon. Will let you know. Thanks for the addit info.
  6. bison
    bison
    Expand Collapse
    Moderator
    Staff Member
    Dec 19, 2005
    16,526
    1,247
    Offline
    It will inject the fuel 2* sooner. Does this have any effect on anything at 3000+rpm. Absolutely not.
Share This Page
