T Carter
- Sep 13, 2012
I have a 87 grand national with a smc kit, running denatured alcohol. My question is can i run methanol with this kit without issue
SignUp Now!The denatured was used as it was less corrossive. And a lube like Klotz(WD40 would also work) was used to help lubricate the EFI pump used. The big thing is the age of that kit and life expectancy on those pumps sitting in alcohol. Amazing that its still working. Use the test button and watch your knock gauge.thanks for the help im new to the forum, my kit has inside pump, what is your take on the denatured alcohol? do you like it? or no
+1look for no knock ,
check the gauge on bottle while holding the test button and make sure its building pressure
