26918's are about the minimum id be using if i was looking for 125+mph. There is no point in comparing a soft LS lobe that is used in a naturally aspirated application to a fast ramp high boost application. If you can get around 140 on the seat and about 400 open and not coil bind you will be ok up to about 30psi and 5700 rpm on the typical lobes out there. If youre running the most aggressive lobes you will need more pressure. There is no point in chasing spring pressure. A little extra does no harm. Too little will leave you scratching your head. Ive used comp 941, comp 26918, comp 26120, and PAC 1203 with great success over 135mph and boost in the high 20's. Ive gone to 33psi/6300 rpm with the PAC springs. If youre looking for 140mph you need to look a little closer at the springs. I woudlnt use anything that was less than 165 on the seat and 420 open with the hyd grinds out there. Im currently running about 200 seat and a little over 500 open on the engine in my black car. 885 lifters required. Ive got over 3000 street miles on this setup. Beyond that you should just consider a solid lobe. Dont try and run a lot of spring pressure on non 885 hyd lifters. The problem installing any spring with any nut on a buick head with the standard valves is that the installed height becomes an issue once you start getting into the .580 lift range. You just cant throw any double spring on there because you will coil bind.
