turboculosis
Pleasant peasant
- Jan 19, 2002
Well I've been trying to chase this off idle stumble for some time and had no luck in getting rid of it completely.As I tried to disconnect the cam sensor to verify if it was set incorrectly,the idle got worse and stumbled even more.Is it safe to say that it's not the cam sensor setting that's causing the stumble?FWIW@idle--
TPS:.42/4.60 WOT
IAC:18-19 "P" and 22-26 "D"
MAF:9 g/s
BLM's:130(@off idle stumble-down to105 then jumps up to 150's)
FP:40 line off
Vac:10-12(suspect small vacuum leak)
O2's:irratic (jumps all over)
TIA
TPS:.42/4.60 WOT
MAF:9 g/s
FP:40 line off
TIA
