Hello,
I just purchased an 87 GN and added some modifications. Unfortunately, I did them all at once so it will be harder to troubleshoot and now can't build boost past 11psi according to factory boost gauge. Before changes the guage showed about 17psi. I added new TT chip, RJC Power Plate, 3" downpipe, R43TS plugs gapped at .035. I tried adjusting the wastegate tighter a few turns and then take a run test and by 10 turns in total it only added 1 psi of boost. After my last test run, I started hearing some noises in the engine. I am now afraid, I may have a more serious problem in the engine that is not allowing boost. I had a scanmaster hooked up and there was 0 KR and O@ was over 750. Any ideas?
Thanks!
Thanks!
