blackdeathtrap
smoking six barrel
- Apr 1, 2010
heres another good question are you machanicaly inclined
SignUp Now!i am not but i want to learn how to beheres another good question are you machanicaly inclined
do you have links to where i can purchase them and what exact model?Keep it stock except scan master, hotwire kit, pump, fpr, and chip. Save yourself a whole lot of headaches. But if youve got to go past that, an exhaust (pypes is cheap), k&n filter, and a down pipe. Had that on my car for awhile and it was alot of fun after riding around stock.
x2.....that was the biggest bolt on increase that i did .5 sec.......You will benefit most with a 3" TH style down pipe and free flowing exhaust. Cold air intake won't buy you much.
how do i make the cold air kit? do you have links to the 160 deg, t-stat? how do i bypass the coolant line?One thing calls for another. First thing for sure is a Scanmaster. 160 deg. t-stat. bypass coolant line to throttle body, port and polish turbo inlet bell,make the cold air kit yourself, get a Walbro 340m pump, hotwire, Accufab adj. fuel pressure reg, fuel pressure guage, and a Pypes exhaust with the racepro mufflers. Next, port the stock exhaust elbow, get an adjustable wastegate actuator, a boost guage, and get a Kirbans 3" dp. Get a Duttwieler neck welded on the stock intercooler, get a Pat's 2600-2800 12' converter, use type f tranny fluid, and finally, get a Turbo Tweak 93 street chip and injector combo burned for the setup. It will haul ass!
Lee
Lee
Im not actually in socal I just want to live there so bad. I live in central New Jersey but im going to college in the summer either in Arizona or California. maybe Lousianna but most likely the first 2Where in SoCal are you located? There's guys down here that would love to get together and just talk buicks. Also, check out the swouthwest section at the bottom of the board. Congrats on your Buick!
i like this thread it seems to be motivational to me i got my new upper control arms on and my new headers with cooper gasquets on will this convo was happening today just need to put cross pipe on the the fun stuff commes next
