Chris McDade
- Jul 13, 2001
Ok guys I've been fighting this problem for a couple of months.
The car won't pull pass 5150rpm. I've replace the following, plugs, wires, tried different coil packs, tested both my fuel pumps, replaced valve spring , check the cam for wiped lopes, ran extra ground wires.
Im not lossing any fuel pressure during a WOT blast. If I leave the car in drive and make a pass it runs ok, but If I make a blast in second gear and try to manual shift it, it won't pull pass 5150 accourding to turbolink. My O2 volt are anywhere from 750 to 812 during testing.
Im lost right now. Im not sure what to check next. Im thing it could be the converter.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
