P
PC_87GN
Guest
2nd is a little tight and it will not pull down into 1st. I can lay under the car and push it in with the wife pulling the shifter, but it won't go without that. How do you adjust the cable? All I saw was a nut and a slot on the shifter arm on the tranny. It was adjusted all the way forward and it would seem that would be the way to go. Perhaps the cable is stretched?
Any other ideas or things to try?
THanks
THanks
