Crazyx4
- Aug 13, 2005
i was at the track yesterday, sitting in the staging lane ready to make a pass. i had made three runs already. car was turned off. it was my turn to run so i tried to start the car. it would crank and try to run but die. checked fuel pressure,fuses, etc. i had ran the cooling fan with a toggle switch with the key off to cool the car. the cooling fan relay is bad but there is two more relays with it. i don't know what they are? i checked the car today and it will crank but it doesn't try to run. with the xfi i can't read any codes. crank sensor,coil pack,cam sensor? i did check the cam sensor with the tool it looks like it is working.
