sorry forgot to look on my car, but im thinking that it was the wire that goes from battery ground to engine block. so try and follow the ground wire from the battery and see where it leads you. its possible when the bracket was unbolted that it fell down somewhere. i believe on mine it was between the bracket and the block. if the block is not grounded to the block like its supposed to be maybe it could causes some issues that bad grounds cause but im not sure, just tryin to help
my post above is supposed to say if the battery is not grounded to the block... not block to block...oops! any luck lately, if not u can probably send the chip back to eric if u havent already and get it reburnt or a new one.
