ok translater now set to on - on - on - off, fuel pres back to 43 line off, car idles kinda crapy . o2's under wot goes to 875 but just as i give it gas #'s drop off alot then jump up, kind of like when you let off the gas o2's drop off .
AF, idle is 07 but when it almost dies at idle it drops to 6 then when the moter saves itself from dieing go to 08, under wot AF's go up to 117...........
BL's idle 49 but will stumble around to 65...... LB 22, 48 , 43 under wot 255
TPS .44 under wot goes to 2.90,............IAC moves around 11 - 51.........
well my typing and even spelling suck.........being that it is be kind to animal
wk it would be great if i could call some one and try to talk about this, or if no one wants to give out there # i can see that or if you know and can help me out pm me and i'll give you my # and call me collect. thanks mike
Adjust the TPS before you go any further!
.42-44 at idle and around 4.6 at WOT (but not higher than 4.8) measured via the pedal.
If you measure at the throttle stop on your T-Body and your pedal isn't going to the stop at WOT, it won't be accurate.
It's a delicate adjustment but once you get the hang of it, it's a piece of cake.
with ingine off but key turned forward if i push gas peddle to the floor TPS goes to 4.5
i realy wish i still lived in milwaukee county , as i would drive this pos to menards and forget to remove the keys
i had a tt chip for 100 octane, but i took it out and replaced it with a reds 93 chip as i had no way of getting 100 octane at the time but the car runs the same with both chips...
mods and car
87 gn 53,021 org miles
after market fuel pump
hot wired
k&n open air filter
adj fuel reg
after market exhaust
42 lbs inj
te44 turbo - translator came pre set
i have my old sm #'s but tonight i'll get all new #'s one at idle warmed up and one set of #'s just as the car stumbles, and hopefully that will get me the help i need to get it running so i can enjoy the car when i drive it.. or just hope these cars keep gaini=ng in $ and just sell it when i can turn a good profit........oh well thanks for any and all help,mike
so the only difference from car running good and bad was a new turbo being installed?
if so maybe the ground wire that goes down to one of the turbo bracket bolts is loose?
