Car runnin kinda crappy.... and 10mpg.. help
  • Thread starter Thread starter Datsunboy
  • Start date Start date
D
Datsunboy
Guest
Guys, my car when cold idles like poo. The idle fluctuates like it wants to die. When warm it still idles rough. When its warm it idles like a lumpy cam would.
I am also getting 10mpg on the highway on a stock 85gn. Any ideas as to possible problems? It was a pretty windy day, and i like boost.. is 10 normal? I didnt spend that much time on the throttle! What are you guys getting for milage??
Thanks guys - Evan
I get more then 10mpg with all my mods, i would make a check list and go over the hole car.
Check for vac leaks , exhuast leaks , cam sensor , tps , and check the plugs and plug wires to makesure every thing is on the money.
To start with, it may need a new O2 sensor, and reset the IAC per instructions on www.gnttype.org in their tech section (Bad O2 sensors cause poor mpg). Many useful fixes for a variety of common TR problems can be found there. If possible borrow a scantool to check the car for knock, O2 milivolts, IAC readings, etc. If using a scanmaster II, check the cross counts and that should tell you if the O2 sensor is bad, they should cycle about 40 counts if good.
Thanks guys, this site is very helpful. I am a buick newbie but not a turbocar newbie. I have a turbocharged datsun 240z. but since i used aftermarket FI, i dont have great factory EFI troubleshooting skills.
Ill look into the stuff you mentioned
Looks to me like i need to start with plugs and wires, they are pretty nappy lookin.
02 sensor seems easy to get too so maybe I should snag one of those too. Can you guys give me an idea as to what millivolts i should be seeing? I can put my multimeter in the car with me and take measurements and check if its bad.
Thanks again guys - Evan
Ps.. I am planning on doing the 87 upgrade sometime soon. Really need to fix the rough idle first though, its annoying!
