Jan 23, 2020 #1 C car95 New Member Joined Mar 23, 2013 Messages 20 87 GN smokes out tailpipes when decelerating, not under boost or idling
Jan 24, 2020 #2 C car95 New Member Joined Mar 23, 2013 Messages 20 car95 said: 87 GN smokes out tailpipes when decelerating, not under boost or idling Click to expand... I'M just trying to narrow it down to turbo seals OR, I appreciate anyone's opinion. THANKS
Jan 25, 2020 #3 SCOOBY DOO BASED CANADIAN PATRIOT!! Joined Feb 18, 2007 Messages 3,948 I'd suspect valve seals...but it should be doing it at idle when vacuum is highest.
Jan 25, 2020 #4 C car95 New Member Joined Mar 23, 2013 Messages 20 Scooby, I appreciate you taking the time for your input, car has about 70,000 miles and basically I just noticed the smoke and that is the only time it appears is on deceleration. Thanks
Jan 25, 2020 #5 T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Messages 10,084 For a test, delete the pcv and see if it still smokes.
Jan 25, 2020 #6 C car95 New Member Joined Mar 23, 2013 Messages 20 TurboBuRick said: For a test, delete the pcv and see if it still smokes. Click to expand... TurboBuRick said: For a test, delete the pcv and see if it still smokes. Click to expand... TurboBuRick said: For a test, delete the pcv and see if it still smokes. Click to expand... Thanks, Turbo for you're input, if it does not smoke at that point that would mean?
Jan 26, 2020 #7 michael evans Well-Known Member Joined Feb 27, 2008 Messages 1,140 car95 said: Thanks, Turbo for you're input, if it does not smoke at that point that would mean? Click to expand... Your pulling oil form the crank case.
Jan 26, 2020 #8 C car95 New Member Joined Mar 23, 2013 Messages 20 michael evans said: Your pulling oil form the crank case. Click to expand... Thanks for the reply Michael, help me a little bit what would the fix be? Thanks!
Jan 26, 2020 #9 michael evans Well-Known Member Joined Feb 27, 2008 Messages 1,140 car95 said: Thanks for the reply Michael, help me a little bit what would the fix be? Thanks! Click to expand... New PVC valve
Jan 26, 2020 #10 C car95 New Member Joined Mar 23, 2013 Messages 20 michael evans said: New PVC valve Click to expand... Thanks again Michael, I just put a new one in no change.
Jan 26, 2020 #11 SCOOBY DOO BASED CANADIAN PATRIOT!! Joined Feb 18, 2007 Messages 3,948 How many miles on the engine?
Jan 26, 2020 #12 C car95 New Member Joined Mar 23, 2013 Messages 20 SCOOBY DOO said: How many miles on the engine? Click to expand... 70,000
