C car95 New Member Joined Mar 23, 2013 Jan 23, 2020 #1 87 GN smokes out tailpipes when decelerating, not under boost or idling
C car95 New Member Joined Mar 23, 2013 Jan 24, 2020 #2 car95 said: 87 GN smokes out tailpipes when decelerating, not under boost or idling Click to expand... I'M just trying to narrow it down to turbo seals OR, I appreciate anyone's opinion. THANKS
SCOOBY DOO BASED CANADIAN PATRIOT!! Joined Feb 18, 2007 Jan 25, 2020 #3 I'd suspect valve seals...but it should be doing it at idle when vacuum is highest.
C car95 New Member Joined Mar 23, 2013 Jan 25, 2020 #4 Scooby, I appreciate you taking the time for your input, car has about 70,000 miles and basically I just noticed the smoke and that is the only time it appears is on deceleration. Thanks
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Jan 25, 2020 #5 For a test, delete the pcv and see if it still smokes.
C car95 New Member Joined Mar 23, 2013 Jan 25, 2020 #6 TurboBuRick said: For a test, delete the pcv and see if it still smokes. Click to expand... TurboBuRick said: For a test, delete the pcv and see if it still smokes. Click to expand... TurboBuRick said: For a test, delete the pcv and see if it still smokes. Click to expand... Thanks, Turbo for you're input, if it does not smoke at that point that would mean?
michael evans Well-Known Member Joined Feb 27, 2008 Jan 26, 2020 #7 car95 said: Thanks, Turbo for you're input, if it does not smoke at that point that would mean? Click to expand... Your pulling oil form the crank case.
C car95 New Member Joined Mar 23, 2013 Jan 26, 2020 #8 michael evans said: Your pulling oil form the crank case. Click to expand... Thanks for the reply Michael, help me a little bit what would the fix be? Thanks!
michael evans Well-Known Member Joined Feb 27, 2008 Jan 26, 2020 #9 car95 said: Thanks for the reply Michael, help me a little bit what would the fix be? Thanks! Click to expand... New PVC valve
C car95 New Member Joined Mar 23, 2013 Jan 26, 2020 #10 michael evans said: New PVC valve Click to expand... Thanks again Michael, I just put a new one in no change.
SCOOBY DOO BASED CANADIAN PATRIOT!! Joined Feb 18, 2007 Jan 26, 2020 #11 How many miles on the engine?
C car95 New Member Joined Mar 23, 2013 Jan 26, 2020 #12 SCOOBY DOO said: How many miles on the engine? Click to expand... 70,000
