Car wont start!!!!!!!!!!!!!!!!!!!!!!!
fast-turbo
Ok i just posted a message about my cooling fan not working and i have just replaced all three fan relays and also the coolant temp sensor. I just put the relays in 5 minutes ago and i went to start the car and nothing happened? When I turn the ignition on all of the lights come on and I can hear the fuel pump but when i go to turn the key nothing happens. The engine wont even crank over or nothing please help. This car means the world to me and all of a sudden it has gone to hell.
Sounds like maybe fusable link problems?
There are 3 of them connected to the starter solenoid.
car wont start
Thanks for the advice i will check that out and let you know what i find. thanks very much
car is running great!
Ok so after a few hours in the garage i found the problem the negative battery cable was hooked up to the batttery but nothing else I guess the bolt came loose or whatever happened so I went and replaced both cables and wha la the is back. It was raining pretty hard last night so I decided not to take it out and give it hell for causing me pain...lol Other than that she is back to normal. Thanks for all of the help this website is the best.
:D :D
