I purchased on of Casper's cam sensors. There is a warning in the instructions which says do not use with any other CCCI ignition. I have a TR6 ignition. The stock cam sensor works fine with the TR6 & the Casper sensor is a replacement for the stock sensor. The Casper cam sensor should logically work well with the TR6 ignition. Is someone sucessfully using the Casper cam sensor with the TR6 ignition? Just trying to get confirmation. Thanks
