Dr.drivability
9 second wannabee
- Oct 1, 2005
Anyone use the caspers xfi exteder harness?
Yes, I was curiuos if I needed anything else to extend the box.You mean the 36" adapter?
So the harness goes under the carpet?I don't have a picture but if you run the wires it's so tight there is only one place you can mount it. I believe only three mounting tabs were on the floor too, one was held up off the floor. You'll see what I mean when you put it in. If I remember right the lights go to the rear & plugs to the front. The harness is so short there really is only one way it will fit.
This works out well, and you can see it.Do one of you have a picture of one mounted? Where do you bolt it to? Where do you run the harness? I Have my seat out right now, so I guess this would be the perfect time! Thanks
Yes sir! Everything is completely hidden when finished, unless you look under the seat.
I have the long harness as well as I wanted to keep it out of site as well. Is there any issues with the seat afterwards as far as the travel back and forth?
Do you know Harry Gann? He is from port huron I believe.
Harry died a few years agoI got a few questions on this guy. Anyone know him? Harry Gann?
I told them that in bowling green last year & they acted like I was some sort of moron that had no clue
Evidentally they have never actually installed one.
Caspers wasn't at BG last year. And, yes, we have installed a few....
