SignUp Now!Caspers is alive and well
Try calling instead, during business hours. Otherwise, leave a message. Your emails must be getting bounced before they make it to the server. We respond to EVERY email we receive.
Digital dashes are a common repair, doing them every week. If the dash had been repaired previously, and has another problem, it can be repaired. Unless one of the displays is broken, then it would be replaced.
Caspers is going thru a transition website change, but emails will definitely get to where you send them.
If your problem is the segment as you described, you will need to send your dash in for service. Pack it well, insure the parcel, use a large box with packing noodles, and attach your information and describe the problem. We repair dashes regularly.
