turbobooster
- Nov 12, 2002
im just wondering how u guys r going about ur cat dump/test pipe setups ? i have a 3 " mease dp i also have the dump that it came with that slips over the downpipe with a 4 bolt flange on the oppisite end i cant seem to find a 3 " cat with this slip in to go over my dp wat im wondering is for those of u that have to pass emmisions are u guys butting the 3 " cat to the 3" dp then using a band clamp ? or is it a 3" cat that flares up and slips over the dp and then using a stepped ban clamp? im also thinking if u use the slip connection at the dp wen u go to switch one out for the other the dp has to b removed in order to have clearance to pull it off so that the 4 bolt flange on the exhaust wont b in the way right? thanx
