Center Housing Journals,Thrust Bearing etc
TTipe
Snake Skinner
What is the proper supplier to purchase the center housing journals (o.d. 0.683", i.d. 0.460", width 0.405") thrust bearing etc as shown in the pictures. The housing is Garrett P/N 430683. The center housing is from a TE63E (P trim exh wheel). DSC_0142.JPG DSC_0142.JPG DSC_0143.JPG DSC_0144.JPG
Large shaft journal bearings, thrust bearing, and thrust collar with sealing ring. Start a conversation with me. I have all this and any other parts you might need for this. I see a lot of embedded metal in the thrust bearing and one of the journal bearings has a deep score that is visible even with the bearings the way you have them in the pic. Chances are the bearing housing bores are scored also
