Century Transmission Cryo forward drum
brian
Senior Member
This part was in an old PMAC (Century) trans I disassembled.This is the most common shaft in the trans that breaks under load.
The drum is also nickle welded at the bottom of the splines. It is in excellent condition with the bushing installed. This should be quite a step up from stock.
$150 shipped to you.
Thank you, Brian
hipsibri@cs.com
