Champion iron heads
NY_GN
Planning next secret evil upgrade
Cracked head, want to upgrade, need champion iron heads now.
******found a set, thanks.
If you cant find the champs fast... consider getting a good 8445 core and doing some basic cleanup..
There are a few good porters around the country that can get you just as close ( some even will out do the Champions easily) and be within the same $ mark.
depending on when you get these guys in their slow season.. I'd bet you could get the heads sooner then you would from Champion.
The Champ Irons work very very well and are proven .. but I've also found that there is nothing all that special about them and one can easily get the same results if they know a good source for port work...
just to give you a idea ... I did a set of 8445's for my own GN .. nothing special at all ... car Ran in the 10's easily
I can port you a set of iorns . I put down 580 with my iorns that I ported . Here are acouple pics of some basic clean up of the bowls
Nevermind, I'm gonna buy from a vendor, if any of their frigging sites work. One gives an error trying to check out another out of stock or 2 month lead time, holy fucking shit, I just want to buy some champion heads!
I've got them so message me if you want a set
Hook up with Bison, plus he is only couple hours away from Brooklyn. Save on shipping and headache.
This is more what I had in mind ..
Simple , Effective, Frugal
Fuel it, tune it, small turbo, E85 ... mid 10's eazy peezy
I had more time in the valves themselves then the porting .. weekend job and well worth it.
