My statement was a general statement.
I.e.- Vehicles driven short distances (oir started and ran at idle to "charge the battery" or "let the fluids flow" or "gonna move it outta the garage every few months and take it around the neighborhood", etc , especially in cold weather will build up moisture in the oil from condensation and combustion gases by-passing the rings. This build up of water will cause acids/combustion by products to be created and get in the oil resulting in the formulation of sludge and accelerated wear.
There are additives in the oil (detergents, addp, viscosity improvers, etc), which are designed to combat/control these acids, but they deplete over time, and can only control so much moisture.
It can be worse to drive 2,000 miles in the winter of short trip driving in six months before changing oil than six or seven thousand in the same period.
One example is the is E85 cars that their blow by gases are going to be worse since the ethanol attracts more water than reg gas. Also, some folks tunes are richer than others when the engine is cold which will contaminate the oil.
Other is place and climate where stored is more humid and/or the temps swings while sitting causing teh block to sweat. Engine ring condition, type of oil...... Just too many variables.
IMO if your car is stored in a place where the humidity and temp is controlled and the car isnt started while stored then maybe change less often/once a year.
Think about it if your werea manufacturer of a product that requires oil to be changed covering every scenario would be a thick section just on oil change situations. Being presented with that they say change the oil based on time and miles.
I once had a 86 GN brought to me to work on and the old guy had bought the car new. He had log books of every (yes every one) oil change, fuel up, mileage per month, etc.
The car had a reds chip in it that was stupid rich at start up and only had 1800 miles put on the car in 2 years and never had the oil changed in that time. Reason was never reached his 3 k mile change interval. The oil was black as tar and had a strong fuel smell.
While that may be a extreme example due to the fact that the oil was black and most would change it do to color. But this was a garage whore (not climate controlled) and pampered.
I think there is something to be said about cars that are driven frequently and blasted WOT on a regular basis and is maint properly vs. putted around garge queens that are hardly drove or driven short distances.
Not saying that anybody in this thread just saying.
