Changes.....Meg's Dad
Steve V
Steve V's Automotive 757 560 2782
I have John's very nice GN at my house for somes changes. Going to change the manners of it with some maintenance tossed in. Tonite was fuel pump time. This is what I found
This is what's going in...
That's officially crazy.
Reminds me of Apollo 13 with the wires' insulation burned off the cryo tank heaters
Now the next discovery. Looks like this is an old hotwire kit. Look at the terminals..can you say high resitance? Hey John order a new one!:) And lastly a new fuel filter.
Yet the car undercarriage is quite clean - so it's not a mud crawler by any means.
Good case for always using lithium socket grease and shrink tube when you can.
Today I installed new front hoses, bleed some brakes. Messed around with some wiring under the hood and dash/console area. What a hornets nest. Removed upper control arms for new bushings. Went wildly crazy cleaning the front of the frame. New issues are melted positive battery cable due to not being far enough away from pass side header. I also installed the line for the stock style trans cooler. This a non lock tranny and it used a single pass external cooler only. I am utilizing the new cooler in the rad tank with a multi pass external cooler. Here are some pics in no order.
Also added front bilstiens. Engine had a girdle and yup it's leaking..looks like s stock style gasket was used instead of a cork one.
What a mess I made of the floor:)
Lucky for me my 2yr old slept in so I snuck out to the garage and did some painting.
These pics show me some spots I missed....gotta go touch up:)
Rustoelum satin black 7777
Hey Steve can my car be next? It looks like you are doing really nice HQ work!
Wow, those lines look crappy! Good thing you caught that. That ride is going to be much happier when you're done. Nice shop too. Wish I had something nice to work in...
Core support painted..looks gloss will be satin when dry.
Arms are ready with new moog bushings. Next is some paint. Core support back together with new stickers. Powerlogger almost complete.
So why you thinking the pump wires and plug got hot?
High resistance is my guess, look at the hotwire plug pics. The tank opening had to be massaged to remove and install, not a fan of that. So new racetronix set up with new hotwire kit should hook him up. He's down grading to a 6262 bison special for street ability.
