Crazyx4
- Aug 13, 2005
I currently have a jrnl. p70 and I bought a db hpq 71. I'm at 70% dc on my injectors. How much fuel do I need to add to the VE table?
SignUp Now!I currently have a jrnl. p70 and I bought a db hpq 71. I'm at 70% dc on my injectors. How much fuel do I need to add to the VE table?
The gain below 5500 rpm will be minimal if he was running the 70 p trim all out. I dyno end back to back and actually picked up going from a 66gtq to a 72 p trim a couple years ago. The gain was minimal till rpm was over 5600. Then it took off. At 6000rpm it was almost 100whp difference. Peak power was only up about 20whp though. The 66 compressor couldn't keep up with the engines demands. He should pick up at least 100whp by increasing boost 5psi though. On my engine the clipped p trim didn't cause a problem till about 77-78lbs/min. That's enough to run in the 9's.It would seem you will gain power going from the p to q wheel. I'm real interested to see what it pickes up pound for pound. I'd guess the gain is going to be in the 100rwhp range on an all out motor like you have.
