usetaboost
SAY CAR RAMROD!!
- May 4, 2005
There are losts of debates on what gives better results.... high boost, low timing or the reverse. .
I vote BOTH
SignUp Now!There are losts of debates on what gives better results.... high boost, low timing or the reverse. .
yes numbers are ok.Yes, I understand that is probably the best place for it to be viewed, but I don't like it there. Now that we have that out of the way, did you watch the video? Any comment on numbers?
not a good way to get help if your going to be an a$$ about someones comment.I'll be the first to let you guys know and say "I told you so". Can we get past the placement now?
more the reason to move the damn scanner. anyway just because other people are are running higher boost than you on pump gas is because each car runs different. why do you insist on leaving the boost at that number. leave the timing at default. 20/18 i assume. and lower boost to 14 and keep the fuel at 20% and try adding 3 to 5 psi on your regulator. you did add a duttneck which will make you have a denser charge and run leaner. now add this 90 degree heat to the engine compartment and this only makes things worse. the duttneck will make the same power at 14 as a stock intercooler would at 16. hope his helpsLook how nice this car is, it would be a shame to hit a tree.
I vote BOTHIt makes a stock turbo car fun:biggrin:
Well, I'm no expert, but I do have a car that runs nice
I'd do something to drop that temp. My car on the hotest of days only hits 195 with the ATS of 110 and I thought that was high. Your TP at .46 is in spec, but I perfer .42. 12.8 Volts, wonder what it reads when your getting on itMine's in the 13.8 range. IAC, mines around 21 or so.
I have a K&N in the fender bring in fresh air, but you car seems too hot. I'd adjust the TPS and IAC and make sure your getting the correct voltage.
I didn't see, but you FP needs checked.
Brady,
Yes, your the second to suggest my maf is failing. It's on my list of things to purchase. I never see 255 on my scanmaster. The highest numbers are 218-225, I tried taking it off and cleaning it. I also just purchased Razors ALKY kit and the actuator is an HD. I hoping with the alky an hd actuactor will be the one I need.
you may install but do not run the alky kit till you get the car running perfect on pump gas and knock free. you will only be bandaiding a problem
Why did you have to rain on my parade, lol. I was thinking life would be perfect after alky kit. I'm trying to work on a maf deal now.
Humor me, is there any chance if the air filter is dirty or where its placed in the engine bay could contribute to low AF numbers? Can you tell me what RPM at WOT I should see 255? Is it at full boost? Whats the criteria for max AF number on scanmaster?
Turbo RX-6, is that the unit that adjust AFR for you on the fly? Is it MAFLESS?
