Got the motor stripped down to the basics. Heads, lower intake, left the water pump and timing chain cover and oil pan on. Crank has the dampner and pulley on it.
Need to pull the pan to check main and rod bearings...
After I get them bearings all done, figured i could roll the block back on stand so the pans on bottom and then do the timing chain and water pump... then I can see if it has a stock cam. Then change the valve springs.
Any suggestions?
Any suggestions?
