I was doing some mainance on the car and decided to pull the pvc valve to check it out. I have never seen any mention of the one way ?? check valve that is between it and the hard metal line going to the vaccum block. How is it suppose to function? I can not blow thru it, i can get compressed air thru it although i did not hit it hard with a lot of psi to see before you guys inform me.
Is it suppose to take a lot of presure to blow thru?? Do you even need it? What would happen with out it?
