#1Take the whole console and stock shifter out including the shifter cable.
Tuck the shifter light socket up in the dash you will not be needing it anymore.
#2 Get two pieces of cardboard. Make a template of the base of your Cheetah shifter like the picture bellow. Connect them with tape and outline the Cheetah base to the console shift plate.
#3 Then set console back in car minus the console plate you just cut out "do not mount".
#4 Take the Cheetah shifter "minus cable" and set it inside the console.
You might need to cut some carpet away for fitment.
#5 Look at the height of the cheetah shifter. It will need to come up to fit flush with the top of your console. Get two plates of Alu/Metal 1/4 thick like pic bellow for mounting the shifter bracket up front, and in rear. You will need a drill and hardware nut's, bolts etc.. I cut some small steel pipe to fill in the gap in between the plate & tunnel where the bolts mount.
#6 Once you have everything lined up and ready to mount pull out the shifter & console and reinstall the Cheetah shifter cable. Reposition the shifter back in the location where you have drilled to mount with out the console.
#7 Drill the hole needed for the new shifter cable. "should be on the drivers side of the tunnel.
#8 Now figure out what needs to be massaged on the console for the cable. "remember the console will need to sit flush on the carpet"
#9 Mount Cheetah shifter with your predrilled holes, set the console in place. while still making sure your cut out shifter plate will line up with the already mounted Cheetah.
I hope this helps it's kind of a pain in the A$$.
