chip info. too much timing?
justabuickv6
I'm currently running a PTE 93 chip made for blue tops.
I'm running a best of 102 mph and I'm running out of injector right at 100 mph, according to Direct Scan. Several people on this board has viewed my DS file and advised that I'm running too much timing (21.1) in 3rd. I looked and the entire WOT run was 21.1 degrees. Is this too much? Should it be changed?
BTW, I only get knock right after switching in to 3rd.
PT52
16 lbs of boost
93 octane
Blue Tops
Stock D5
THDP
340 with hot wire
stock motor
Knock Knock
What is your fuel pressure set at? I would like to see your DS file to. Usually 21* is only 1 * from the normal of the 20* chips sold out there.
Thanks Tom
Read File
Just looked at the file, I see where the 02s were starting to fall off. I would replace fuel filter with a new one. Also up the fuel pressure a # at a time until there is no knock. That 340 hotwired is more then enough for the blue tops.
Tom:)
SPOOLN
Thanks for your reply.
The fuel filter is new. My fuel pressure is 46 line off.
The O2 numbers were safe (780-790) Did you mean they were dropping too fast?
Fuel Supply
Since you have a good pump to supply the fuel. Maybe try to adjust the cam sensor. Sometime if its a little off it can cause the car to run a little lean. Seems like with that state of tune (16#) you should have no knock.
Good Luck
Tom:)
