currently having turbo tweak update my chips for stroker motor and will be changing to a double fuel pump setup and wanted to see if that had to be put in the program or if the second pump just cuts on with vacuum.thanks
The 2nd pump should come on at a preset boost level. I don't recommend activating the 2nd pump at anything less than about 18psi boost if you have stock fuel return line.
The chip programming is not affected.
