- May 28, 2001
1. The winch can be mtd external, on the tongue, or in a below floor compartment.
The FL we had, had the winch parallel to the dr side wall. The cable ran thru a snatch block hooked into a flush d ring in the center of the floor.
Not in use? retract the cable, put the block away. Clear floor, nothing to fall over.
Our winch also had a wireless control... A NEAT option on some of the better winches.
As for the winch....A min of 5000# single line pull. {8K is what we used}. Take a look at the newer cables... Not braided steel, any longer.
