ckperformance 2004r manual
Hrmmm..... perhaps you are using a newer or different version of MS Word than I am? I have Word 97 from the MS Office 97 Pro suite. If you left click on "Help" from the main menu bar in Word and select "About MicroSoft Word" it should tell you what version of Word you are running.
hey A.G. whipping is not the word!!!! lol
kurt I have microsoft 2002.... any thoughts?
guys its worth the wait!!
Bill, we need borders-lol
Chris,
I'll give you a hand tomorrow :)
Hi Michelle,
Sorry I don't have Word 2002, but after checking the MicroSoft site, give this a try. Format Picture->Layout->Advanced->Picture Position. See if there is a check box there for 'Float over text'. If so, check it and then try Format Picture->Colors and Lines and see if the drop down menus under Line are now available. If so, select a color for the line and the border should be visible.
klrv6 will be posting a completed chapter.please let us know of any typos.this is how it will be,i am not going to refine it any further.thanks to those who made it possible,that is the link and the info that allowed us to format.
GREAT! another chapter . finally getting somewhere and we all benefit. Is this the chapter with the valve body mods? and the dual feeding? that's the stuff I've been needing for so long. thanks.
Chris, you have probably already done this, but as I'm dense on transmissions I'll post anyway.;)
I'd guess that not all the mods in your book will be appropriate for all levels of performance. If this is true, including a few recipes showing which mods to do for various types of use would be extremely helpful.
Possible recipes: Taxi/Towing (durability), Street performance, Street/Strip, and Competiton Only.
Thanks for all the work that you and Michelle have put into this project!
whats the username and password to view chapter 6? or do u have to buy the manual????????
it has not been tested yet i have the engine out for some nasty leaks to fix. Will have to wait till spring until the tack opens
I need to pull mine and send it back too. And fix the motor.:(
What rpm did you go with?
Thanks.
does the chapter 2 doc open for everyone else? I don't know the rating but i think its going to be at least a 3200
