What's the best clearance to run on the mains??? IOW, what are you guys running?
This will not be a competition build. I'm re-assembling the numbers matching block using all the original hardware. Just new bearings on the mains and rods. But will get a new cam/lifters.
I am to the point of assembling the bottom end.
The factory manual seems to recommend .0003 to .0018 clearance on the mains. Do any of you run looser?
I've measured mine both ways. Plasti-gage, and the mic and bore gauge method.
Mic and bore gauge method seems to yield the following:
.0019
.0019
.0023
.0024
Front to back
While the plasti-gage seems to yield VERY close to the same results, somewhere very near .002 (as close as the eye ball can see plastic spread).
Would a set of -.001 mains fix me up better?
.0019
.0019
.0023
.0024
Front to back
