clocking the turbo
  • Thread starter Thread starter intensepgt
  • Start date Start date
I
intensepgt
Guest
Is this possible to clock the turbo? Turing the compressor side?
Can you let me know. Thanks.
Ryan
I just went through this with a turbo install. Simply loosen the bolts holding on the compresor housing (I think it's like 5 bolts). You don't have to take the bolts out, just loosen them. Then rotate the compressor housing the desired amount. Then retighten bolts in a star pattern. Hope this helps.
Use a 13MM 6 Point wrench,....and there are 6 bolts....loosen them all up, and then the housing should rotate freely!
