Codes, Who do I believe? Powerlogger or Snap On Scanner?
My car runs great but I am having a few small issues. BLM goes to 160 at idle (bad) but is 122 to 129 cruising which I know is perfect. I had the powerlogger hooked up and it said Code 44 O2 sensor. I did notice that the O2's would drop out at idle after about 20 seconds so I put an O2 in it. Here is where it gets interesting. I checked for codes with 2 different devices:
Powerlogger said code:
44 O2 Sensor.
My Snap On red brick scanner had these codes:
41 No camshaft reference signal
34 Maf Sensor or ckt too low
33 Maf Sensor or ckt too high
I do have a Translator Gen 2 with an extender extreme chip. I had lean issues cruising a while back so I changed the MAF, fuel pump & fuel filter, fuel pressure regulator (Fuel pressure was dropping a few psi after long drives) and put in an RJC PCV valve.
So my real question is this, who do I believe for the codes?
I know a cracked exhaust can cause high BLM at idle, I was going to check for that with an Evap smoke test machine.
Thanks!
44 O2 Sensor.
Thanks!
