4-1: 12.40 OHMS
2-5: 12.03 OHMS
6-3: 12.13 OHMS
It dosent seem out of range but the numbers are a little bit out of range so let me know i really hope its not a coil modle. Thanks
SignUp Now!Coil looks ok. 13.5K is the maxkosonen04 said:The reasion im thinking it, is because the car will start up fine and idel alright but when i get moving and press on the gas it just starts back fireing tho the exhasut and just dosent build boost or it dosent run worth a ****, my map sensor is good and my MAF is good and the coil is stock so im just thinkin it. Dont know what else it could be?
Carefully remove the IAC motor and clean it, then clean the seat in the TB, reset the IAC and TPS.kosonen04 said:.......... after i have been driving for a wile like around town and i go and put it in park it will vary in RPM about 500-800 and just hunt around in that area. ........
kosonen04 said:Alright were is the IAC on this car? Also how do you reset the TPS and IAC? What should i use to clean it i have MAF cleaner? Thanks
Jerryl said:IAC reset
http://www.t6p.com/forums/showthread.php?p=13746
http://www.gnttype.org/techarea/faq/IACresetscan.html
TPS reset
http://www.gnttype.org/techarea/maintenance/TPS.html
Leave the MAF alone for now.
Start with your TPS and IAC and go form there.
I have seen these at local parts stores. It came with the car but I would not recommend it. It is too tall and does not fit tight on the filler tube.tenright said:Ok this is off the subject but I have to find out Jerryl where did you get that drivers side breather....I need something like that so my MAF pipe will not be wedged against my breather..
