Here was my combination. It went a couple of 10.3X with the best of 10.35@131 with a 1.57 60 foot.
The only nothing exotic thing was a sequential FAST. You can throw money at one to make it go into the 10s. But if you pick the right parts in the right areas, it doesn't need to expensive. My weak spot was/is the transmission. I don't have the big money for a "good" one. But I daily drove mine, weather permitting, as long as it wasn't broke.
109 block with center steel caps
JE racing .030 pistons
Stock balanced crank, polished stock rods
Johnson Racing big valve ported irons
Anderson Performance roller cam
Home ported intake and plenum, basically gasket matched and polished
Stock 58mm Throttle Body
PT54 turbo 25-26 psi
Stock gasket matched Headers/Crossover
Single Shot Torque Tech with Dynomax Race muffler
3 ½ China downpipe
75# injectors
Aeromotive 1000 pump
Sequential FAST
Turbo 350 transmission
B&M Holeshot 3000
M/T 275/60/15 DRs
Jegster LCA, Summit adjustable shocks, the rest was 1987 stock
All safety stuff was there for a 10 sec car.
6 point MS bar, 6 point harness, Trans shield, DS Loop, Flywheel, metal valve stems, C Clip elims. etc.
