just got my gn runnig and already ran into a problem. water from radiator is mixing with the oil
. my current heads have a receiver groove cut in them and i use a fel pro receiver groove head gasket. i been told by alot of people that u can run into this same problem that i have if not properly installed. i have not beaten on the car very hard and haven't even gone full throttle in the quarter mile yet. my question is, has anyone else ever run into this problem using them gaskets? also, could i switch to a cometic head gasket without milling the receiver groove out of my heads?? i've been told this has been done. the reason i don't want to mill the heads is because i had to mill the receiver groove out once and cut new receiver grooves and i do not want to raise the compression ratio.
