I just rebuilt my motor and installed a 210-215 extreme cam and comp. cam roller lifters. Now I have about 200 miles on the motor and have lifter noise bad!. I set the pre-load the way I was told. After I drive the car and bring it up to normal temp of 160 to 180 degress and the oil pressure will drop to about 20 lbs and it starts clacking. I can give it just a little throttle off of idle and it quits cause the oil pressure will go back up.Has anyone had this same trouble? I am using castrol syntec 10w30. Do I need to go to a different oil or what? I have checked the oil for signs of a spun rod bearing but do not see any metal at all. What do I need to do to stop this or do I just live with it?
