turbobitt
- Feb 14, 2002
Well, I believe turbo bitt at least has a good explanation and he may be right. But, I am like the others about the lifters being in contact with the cam at all times and should not be making the ticking noise.I once had a small block chevy with a roller setup with a bigger cam in it than in my GN and it did not make the noises that my car does now. So, turbo bitt, tell me why? Keep the thread going!!
Most of my experience has been with mech rollers. Talking with other engine builders , Specifically Mopar Hemi's , it seems that people are afraid of going to large on the springs. This may explain if the noise is due to a no-follow. All things being equal, hyd. lifters are the heaviest of the four types(solid,hyd,solid roller, hyd. roller). Wouldn't you think the demand on the valve spring be more ? Again, this is a critical ballancing act. The lifter bleed down rate and the spring pressure must live in friendly harmony. Again, my personal thought is that a OEM hyd lifter probably has a much slower bleed down and as a result, less desirable in performance applications but much quieter in street applications.
Allan G.
