I looked at my cam card to see the rpm range and it is not listed, so then I went to Comp Cams web page and typed in the part number and it said no matches....then I typed in grind number again ....no matches
I have the 210/215 roller from Full throttle I went to their site and it does not have the rpm range listed either.
Why does the part number or grind number not come up on the Comp site?
Also if any one else has this grind do you know the rpm range?
