KWIKR 1 said:Razor , with those clearances was the crank ground on the "high side limit" ? thanks .
I only use un-ground STD STD cranks from junk yard finds that just need polishing
When using ground cranks.. take your measurments and have the shop grinding the crank know what your doing.
Takes patience to build an engine. And it is either rite or it isnt.
Easy to throw stuff in and go..Hard part is catching a machine shops mistake in the process when its not obvious. And dont push a shop to have your engine ready by X time or else.. :redface:
