Complete fresh 274 Stage II off center
re-evaluating
Can't even re-member
4.015 bore (1 sleeve) plus 2 extra pistons
3.6 BMS crank std. std.
TA heads these heads out flowed Chris Lyons's Champion ported GN1R heads significantly on the same bench same day by HIS engine builder
230-230 645 lift solid roller cam
Carillo rods
Diamond pistons
custom deep pan
TA ported stock intake with coolant improvements
This is completely fresh pro build by Francis Engineering {Busch team owner} (new pistons etc) wrapped in plastic ready to go intake to pan.
Call for details WILL NOT PART OUT complete motor only.. $13,500
Dave 502-727-5960 or daveunderpressure at gmail. com
Bump
Also have the following brand new parts for sale.
TA performance 4 bolt headers
42-76 turbo (non bb)
FAST XFI set up for distributor
Crane Ignition
Used parts
Metco Fuel cell with twin XP Plus pumps (went 140 MPH)
Hole star 15X11 wheels with Phoenix 28.5X10.5 w tubes
Hole star 4X15 fronts with Moroso front runners 10 passes on everything
Moser 12 bolt 373 gear 33 spline spool with gun drilled axels, lightened flanges, spherical bushings in upper ears (10 passes) complete drum to drum
HRpartsNstuff swaybar
Innovative MSBC with complete CO2 system
Moroso trick springs (front)
CAS single row light weight racing radiator with AN fittings (-20 I believe) with dual fans
how much for the fast xfi and is it complete ready to install, also what would need to be done to go back to the dis setup on a gn car from distributor? thanks mike 818-913-2800
how much for sway bar . and is it the rear bar setup steve 847-878-2689
What is the price on the 42-76 turbo? Does the Crane setup include the distributor and coil?
Thanks,
Jeff
Very interested in the sway bar if it is not taken yet.
Let me know!!!
sway bar
Dave I think i was first to PM you regaurding the sway bar and also sent a second one. please let me know. Thanks, Scot w.
I will trade you a 3 bolt ta header for you 4 bolt one plus some cash if your interested?
Metco Fuel Cell....is this the spare tire location setup? If so what do you want for it and how new are the pumps? Interested in using it as a liquid IC resivoir, but I might be able to use the pumps too.
Thanks!
4 bolt headers
Whats left ? Looking at the 4 bolt headers ,how much $ are your looking for?
Alive again
Sorry guys I have been very sick, finally getting my voice back. I think I have answered all emails and PM's if not please let me know..
Headers are sold
radiator is sold
XFI sold
Caspers harness is sold
sway bar will not fit 8.5 rear end
