ChrisCairns
Senior Member
- May 24, 2001
I'm putting together a secret project so don't tell anyone.
I'm using a production '84 Buick 4.1 block with stage heads. I just got everything back from the machinest and started the engine assembly. I had the stage heads rebuilt locally and had him do the chamber volume so I could calculate the compression ratio. With all the necessary figures I put them into a calculator at .... Engine Compression Ratio (CR) Calculator
With what I "thought" were the correct figures it comes up with a compression ratio of 10.29. Ouch if that's correct.
So can anyone tell me the following.....
I got Dan's stroker kit and simply assumed the stroke was 3.625. Being the weekend I can't phone Dan...does anyone know if that's correct? Second, the machinest said the chamber volume was 49 cc's. Does that sound right?
I've got a 4" bore, said 3.625 stroke, head gasket bore 4.020, compressed gasket thickness of .060, chamber volume of 49cc's, piston dish negative 14 according to my machinest, and piston deck clearance of .010.
Can anyone shed some light on whether my figures COULD be wrong or are my stage head's chamber volume too small for a turbo engine?
Thanks.
Thanks.
