Compression Results
Tin Man
Chasing a knock problem and trying to rule everything out. Should I be concerned with the compression results. Drivers side (1,3,5) are lower than pass. All are within 10%. Motor was rebuilt and has about 1000 miles on it.
1 - 140 2 - 150
3 - 145 4 - 150
5 - 140 6 - 145
Tester is a cheap Harbor Freight unit and was hard to screw in as it has a long hose that gets in the way. It is possilble that it did not screw in all the way and let air escape. Any help appreciated.
Zac
Thanks Mike. Ruling everything out. The DP is most likely the problem and I ordered HR motor mounts yesterday. Got to get it right for Noble.
