budget_crx
- Feb 26, 2007
I have a friend that is trying to convince me that with all other variables the same (chargepiping, intercooler) a smaller turbo would be the "faster" turbo. (because bigger turbos lag) He is claiming that 10psi is 10 psi, no matter what the size of the compressor, basically: a T4@10psi would have no gain over a T25@10psi. He is also claiming that Compressor size does NOT effect the CFM of a system, so the T4 and the T25 would have the same CFM if all other variables were constant, even though the T4 has a much larger inlet and wheel. Can anybody prove this to be true/false so this arguement can end?
thank you
thank you
