- Feb 14, 2002
Fretting on the main cap is quite common on a stock block that has been making some power. That looks pretty minor in my opinion.
SignUp Now!I remember reading a post you wrote a while back dealing with getting enough heat in the motor with aluminum heads. I'm going to find that thread and go over it again.
I was going to use an older set of T&Ds on my TA heads, re-spacing is not a big problem.... But when I checked the geometry the old T&Ds did not have the same travel on the adjustment screw and left me with a almost non adjustable valve train with the proper length push rod. I sold the old T&Ds and got a new set from TA Perf they worked perfect !!Getting closer to getting my motor back. It's mocked up right now mainly to make sure the intake is going to work with the new heads. We cut it down trying to make it fit on the old iron heads that were shaved quite a bit. Doug say's it fits perfect which is a relief.
Now on to the rockers. Some say the HS rockers I have will work with the TA heads with some spacing so Doug is going to take a look and see what he thinks. Otherwise I'll just get the offset rockers from TA and sell my other ones.
I'm hoping to have the motor back and in the car some time around the end of the month.
View attachment 251866 Photo...............assembled in the living room!
Haha, my wife would definately not allow that in our living room!!!View attachment 251866 Photo...............assembled in the living room!
